Any suggestions on removing a broken bulb?
Both parking light bulbs on my '68 Ranger will not come out. The glass part of the bulb has become unattached from the metal part that attaches to the socket. I figure I'll have to break the bulb and then try to get the metal part out. Does anybody have any wisdom or advice?
- 72hiboy4x4
after removing power from the circuit, break out the glass and use a pair of needle-nose pliers to bend/remove the metal casing. easy to do.
and BTW
to the site! there's lots of technical papers and info in the links at the top of the page for you to drool over!
and BTW
re: Any suggestions on removing a broken bulb?
Thanks. I was hoping it wouldn't be too much of a headache.
- 390Nut
What he said, and afterwards, use a bit of emery cloth or fine sandpaper to clean up the corrosion that's sure to be in there. A little dielectric grease goes on every bulb I replace, now. Used sparingly, it keeps the moisture out of the contact areas quite well.
Paul
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- SmokeyBear
Thanks for all the great ideas. I will give them a shot this weekend and I'll let ya'll know how it goes. Thanks again!!
- Joe Kriston
I'm dying to know which one worked....
I finally found time to remove those bulbs. I know ya'll were are the edge of your seats waiting. Anyway, I ended up breaking the glass and using a pair of needle nose to get the metal part of the bulb out. Thanks for the advise.
