A/T Troubleshoot Question...
adak57
Post by adak57 »
I'm helping an older fella detail out his '69 Ranchero. It has , I believe, an
FMX tranny. When you put it in gear, it does nothing.... then Clunk! it goes into gear , and sometimes slips back out, then in....
Is this more than a simple band adjust? It works better after it is warmed up.
I have a growing feeling that we're looking at a rebuild.... :(
I attached a pic of it.... Really nice one-owner rig...
John
'72 F-100 4x4
'70 F-100 project 1
sounds like it may be low on fluid.
rjewkes
Post by rjewkes »
losing fluid somewhere. Probably the cooling lines or seals somewhere.
fuelly.com
adak57
re: A/T Troubleshoot Question...
Post by adak57 »
OK... the fluid checked OK before I initially fired it up. It had been sitting without being started for a couple years.
I was told by one of the farm-hands that sometimes the seals dry up or shrink...? after periods of non-use.
Initially it seemed to improve after being used for a couple days but after it sits idle for a day or so, it's back to not reacting to the gear selection.
It really clunks hard going into reverse.
I was going to change the fluid/filter and adjust the bands... but was thinking that if there was a major symptom you guys might know about... then I would probably save the labor and approach the idea of maybe having it kitted... Thanks for any input... :)
John
'72 F-100 4x4
'70 F-100 project 1
yeah that does sound like a good idea. changing the fluid and filter will help it alot. try adding some lucas oil or trans x or something similar to it when you do the change. yes seals do dry up and don't want to seal up correctly after sitting for a while.
'75-4x4guy
Post by '75-4x4guy »
check the vacuum lines that go to the modulator on the back of the tranny .
They might not be sealing causing a slight vacuum leak .
Little or no vacuum at the modulator will cause the tranny to bang going into gear ...
Jon
adak57
Post by adak57 »
Sorry I didn't get back with a Thanks! to you guys for the advice...
Had to do some fill-in truck driving last few days...
Good advice... I'll let you know what results I get...
Thanks again !! :D
John
'72 F-100 4x4
'70 F-100 project 1
