69 f-100 short bed coyote swap now Project Howlin'
48prerunner
cab set back on
Post by 48prerunner »
Set the cab back on, I have about 4" between the head and the firewall. Transmission clears the low hump tunnel, but I think I'll put the high hump cover in so will be easier to access shifter.
Had to set a fender on to see how it looked.
Ranchero50
Re: 69 f-100 short bed coyote swap now Project Howlin'
Post by Ranchero50 »
Looks good, it's nice to see someone found something decent at Spring Carlisle this year.
48prerunner
Got more of the rear suspension done.
Airover leaf from Ride Tech
48prerunner
full drop
ride height
front with stock crown vic springs
48prerunner
put it back together to check ride height.
48prerunner
Picked up a set of used magna flow 3" mufflers at lake compounce great buy $30 for pair look like these Image
was a fight to get used part out
but saved $260 Summit lists the at 145 each. should sound good exit 3" just in front of rear wheels.
48prerunner
lifting bed off again lift works greatImage
rust stuff crazy can't believe there is still paint under that surface rust
Ranchero50
Next time, try cutting the inner pipe with a sawzall, blade flat to the pipe and go slow as it'll pop when finally cut through. Then just bend one side if the cut pipe in with a screwdriver and pull it out with some pliers.
Funny thing is your fastback is in about the same shape as my '69... I realized that I was not up to the task of doing it's bodywork and ended up storing it on a trailer under some roofing rubber at my friends farm. (for the last 10 years)...
48prerunner
Yeah a started on fastback way way back then the 37 street rod stole the motor and 9'' rear it rescheduled to be finished after the f-100 and my sisters 65 gt. I have NOS fenders for front and all the 67 shelby fiberglass for it. I bought the fenders back in the 80s up in the far north corner of carlise and carried them all the way out past the firehouse that is back when they used to let you camp on the street. Stupid raccoon torn my insulation down have to fix it before next winter. I was too lazy to go get the sawall was not at the garage. First one popped right out after I ground down the welds.
48prerunner
Swap meet finds at Ford Nationals
Picked up a used bumper has some patina on it to match truck the original truck one is on the left, a brand new one would stand out too much. plus I measured and it fit in the mustang with back seat down and front seat all the way forward. wrapped it in my car cover :lol:
Just looks cooler engine cover and coil covers> I didn't need them to make it run but price was right and I could see what I was getting.
48prerunner
Fabbed up the clutch pedal. I took and ground off the f-100 shaft, then took the clutch pedal and filed the rectangular hole to a square hole to fit the shaft from a 98 mustang cobra pedal set. A couple 5/8" bearings some tube and a aftermarket adjustable clucth cable and firewall adjuster. Image
mustang shaft has the nut on the opposite side.
SATURN5
Post by SATURN5 »
Looking good!
I see you worked your clutch pedal similar to mine. ;)
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
48prerunner
yup thanks little bit of yours copied your ebay bearings then copied the set up of the older mustang rebuild kits from I think mustang steve. I almost used the mustang pedals. Think If I did it again I'd figure out a way to run the cable on the left so it follows the inner fender, I'm hoping once I get the master cyl in it wont stand out so much. I have I think a steeda adjustable cable too came with my transmission. I still need to buy one of those $4 clips to hold it down by the trans. I still want to go six speed t56 or magnum but have to buy ac, alt and power steering so t45 for now.
48prerunner
The Big brown truck keeps stopping and the truck is getting closer to running again.
48prerunner
Project Howlin' KRC power steering
Sorry for dark cell pic. Ford Racing boss alt.
KRC power steering kit really nice I'm glad I finally went with them only took me 11 months to make the decision. Super nice bolts to timming cover block holes no need to cut or tap anything. Lets you use stock ford ac compressor.
