1967-72 f100 parting out
Private parties only. No eBay/Craigslist listings.
rodneyc
Re: 1967-72 f100 parting out
Post by rodneyc »
Do you have factory radio to fit 72? Radio bezel? Factory air clener for 302? Thanks.
59yblockf100
Post by 59yblockf100 »
i have a am out of a 72,dont no if it works,
KRBRASWELL 1970
Post by KRBRASWELL 1970 »
Hello. Do you have any of the A/C P/S pulleys and brackets for a 1970 302?
59yblockf100
no,nothing for a 302,
KRBRASWELL 1970
Thank you.
59yblockf100
have parts still for sale,
turbotimmer
Post by turbotimmer »
I need a good 3 speed column for a 68.
59yblockf100
i do have a 68 that has a 3spd column i no it has no wheel or shifter will have to look at condition,
59yblockf100
did you need parts for yours or a complete one,
turbotimmer
A complete one in good shape would be great, but that might be a tall order.
59yblockf100
will have to check in storage when this weather stops,i have parts for one to,outer case .inner and shaft,its in the for sale section.
turbotimmer
I’ll see if I can salvage what I have. Thanks
Lowell
Post by Lowell »
I am looking for front wheel brake line brackets that hold the brake hose coming off the drum to the hard line coming off the brake booster. They are located on the frame just below/behind the spring perch. I know there can be different styles of these, so if you have any, would you mind sending some pics? If it is easier to text or email, I can PM you with my contact info. Thanks.
59yblockf100
Lowell wrote:I am looking for front wheel brake line brackets that hold the brake hose coming off the drum to the hard line coming off the brake booster. They are located on the frame just below/behind the spring perch. I know there can be different styles of these, so if you have any, would you mind sending some pics? If it is easier to text or email, I can PM you with my contact info. Thanks.
what year,thanks
Lowell
Post by Lowell »
69-72, not sure exactly what the differences are, but I have seen different brackets on different year trucks. If you have some pics, that would help. I could let you know which one(s) I could use
