67mann wrote:
what happened...Life get in the way
This was the sweetest/fastest tear down rebuild...with some nice Mod's to boot...hope all is well
i'm still building as fast as i can, but keep forgetting to post over here
i like it that you're following my topic at the dutch forum!
alright its going to be picture heavy again, this is what i have done so far since december
ordered a lot of parts, almost finished the steering pump mounting brackets.
got a new filler hole for the mustang tank, 2/3 of the parts that i have ordered are at the truck, still waiting for my shipment from NY (flasback f100's)
disassembled the steering, because the new pump wouldn't fit on the steering shaft
some one has been busy with the column
new brackets, the origineal place from the no limit wide ride wouldn't work, so i had to think of something else
fits perfect, but i have to change it, its probably not heavy enough...
rust was showing itself at the cab floor again, so it was time for some paint!
and then i started with the fuel tunnel
so i have to finish up the steering column, with a new bushing or ballbearing.
i changed the leafs in the right way, thanks trickf100!
last week i picked up some parts that were shipped to holland, started installing them just for show
as you see, she smiles again!
i'm still expecting:
inner fenders
LH outer fender
new gauges
hood
cab to fender mountings
dash defrosters
this will probably arrive in about 4/5 weeks!
edit: almost forgot, i have designed an alu plate for the new alu radiator for a SPAL fan:
