Let's See you're under the hood photos
Ron_Hall
Re: Let's See you're under the hood photos
Post by Ron_Hall »
My wife's 71' F100.
Ron
One owner...
Ohiotinkerer
Post by Ohiotinkerer »
Nothing fancy......just some paint and decal work....... :D
1997 Honda CBR 900RR
lennyp
Post by lennyp »
1972 Ford F250 4X4 390 bored .060 over with comp cams roller cam.
farmallmta
Daily Working '69 F250
Post by farmallmta »
I'm the second owner of this F250, originally from Albuquerque. It has a 416 cid FE with a '68 428 CJ crank, '62 406 heads and a 204/214 solid flat tappet camshaft yielding 10.2:1 compression ratio, 390 Perfomer intake, an Autolite 2100 2bbl carb with hand throttle and manual choke, dual exhaust, factory air (that I don't use), power brakes, manual steering, BW T85N-OD column shifted transmission, 3.73 positive Dana 60. That's an oil bath air cleaner and Mercury Lightning Bolt valve covers to clear the OEM adjustable rockers. Down at the lower right is a bit of the Baldwin oil filter, the best filter available. I love this truck!
