Man... I tell you what... that SOUNDS so easy, but you're telling me to cut a wire "close to the ignition switch and close to the connector where it branches off and goes out to the coil. " and to splice in a regular wire. So am I bypassing the ignition switch... is that the deal?lrjetmech wrote:The pink wire is a resistor wire! I changed mine over from the old points set-up in my '69 with a 390. You just cut the pink wire close to the ignition switch and close to the connector where it branches off and goes out to the coil. Splice in a piece of regular wire about the same gauge and you're done. Turn on the ignition switch-you should have 12 volts at the coil! It's that easy. I haven't messed with my ignition since!
This makes me nervous... I'd be cutting a stock wire. Once I do that, it doesn't sound like it would be easy to ever roll back to a points system...
