So I bought an engine from a guy at work that he had pulled down to refresh. I the short block 2 sets of heads all new cam bearings, rings, rod and main bearings, and just a bunch of extra junk he had laying around.
I took the block to the machine shop to have it inspected and that turned out to be an absolute nightmare. They checked the bore and said it was good, dipped it, painted it very poorly, (there was still blue paint showing through the black they put on) installed new cam bearings, (beat the front one to death) and installed new freeze plugs, (the rear cam plug was in backwards, and they knocked one of the freeze plugs into the block and that’s where it still sits).
Mind you this was supposed to be a fun throw together engine. Once the short block was finally assembled things went smoother.
https://photos.app.goo.gl/jmOWxMqVUumJJGs42
I got a Comp cam from my buddy that works there and new springs, lifters, locks and retainers.
https://photos.app.goo.gl/Y0vTq4xWHIB1DpMT2
I told my buddies “this motor doesn’t deserve paint”
I was putting the new brakes on the last week and removing the old fuel lines and cut one of the brake lines on accident so there’s that to do. I purchased some hooker headers from the guy I bought the truck from and put them on as well.
https://photos.app.goo.gl/RZFxvZAosvym8FXG3
So all four wheels are back on and it’s on the ground. Things are looking up!
https://photos.app.goo.gl/6hDgfC7VoahgzN852
Motor is in and beginning to install the fuel injection system.
I had to install a return line for the fuel tank and ended up using the whole on top of the tank for the emissions stuff.
Also the pump had to be mounted below the pickup tube. So I took an old piece of scrap metal they used to hold the “oversized” load sigh. And hacked it up and made a bracket and welded it in place. Oh... the new 38 gallon tank was an absolute bear to get into place. Mainly because the tank strap extensions weren’t long enough and the fill hose was old and crusty.
https://photos.app.goo.gl/VtU5wCTNklyLoabJ2
https://photos.app.goo.gl/Dfs7gzyodgsXsWVN2
https://photos.app.goo.gl/PUJfmkdzLkQIpXPp1
I got the return line ran and some of the feed. Regulator mounted and then ran out of line. Can’t wait to fire it up and drive it! Still got a ways to go! Thanks everyone!
