Changing bolt pattern
- tybob81
re: Changing bolt pattern
if you did the 72 galaxie swap 5x4.5 would a 2000 and up or so explorer 8.8 w/ rear disc work? the spring perches would have to be moved but they are real close to the same overall lenght.
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
- tybob81
If you just wanted 5x4.5 with the galaxie front swap what about the factory drum galaxie rear end? I think they had 9'' rears, could you just swap axles and drums into the f100 factory rear to make it work? or are they a different spline count axle shaft?
