STICKY: Best mods or upgrades you have done to your bump?
Re: STICKY: Best mods or upgrades you have done to your bump?
I have a 3/6 DJM lowering kit on my 68 sb fleet side. When i was installing the front i beams i went ahead and installed all new tie rods, drag link bar, shocks, king pin. On the rear i installed all new leaf spring bushings, shocks, axle bearings. 18 inch wheels, power disc brakes all around, changed the c6 auto column shift to a rebuilt and hopped up AOD with a Lokar floor shift. Installed some nice leather bucket seats out of a yukon, that took some crazy mods to get them to sit right but i got them cheap. The truck already came with a Ron Francis wiring kit but there was some issues there that i had to debug. I am now attempting to build a console then ill get a new stereo system.
- 69timemachine
My favorite mod is my TKO-600 transmission! Having the overdrive is so awesome!
Second place would have to be my JDM 58" Lightning traction bars.
Third place is a tie between my 351 Cleveland, 4.56 gears, Eaton TrueTrac, 3" & 4" drop, sway bars, wide steel wheels, power brakes, and power steering.
Basically, there's no mod that I regret!
Jason
'06 Mustang GT 5-speed
- 69timemachine
Oh, and best safety mods I've done are 3-point seatbelts, disc brakes, and TruckLite LED headlights!
Jason
After trying 2 used steering gearboxes, replacing the box with a Redhead rebuilt one.
1967 F-100 4x4 custom cab.
- 69timemachine
Good choice from what I've heard. Back when I converted to power steering, I bought a parts house reman box before I found out about the Redhead boxes. It's still working fine, but I will definitely put the Redhead if I ever have to replace it!Busboy wrote:After trying 2 used steering gearboxes, replacing the box with a Redhead rebuilt one.
Jason
A '68 '69 front clip minus hood with ranger grill
low and ugly 72 longbed with a 360 converted to a 401 with performer intake and a 750 double pumper carb 260 cam and headers with a c6 auto and stock 9 inch lowered about 5.5 /7.
Build thread http://www.fordification.com/forum/view ... 22&t=79488
- Craigerf100
all the special modification ive done to my bump.
90s explorer coil springs
front sway bar
rear sway bar
91 brake master cylinder
universal dual diaphragm brake booster
f600 cluster
67 mustang bucket seats
3point seat belts
crown royal radiator return bottle
adjustable proportioning valve
front disc brakes
exhaust tips out the side before the wheels
hide away hitch
soon to be:
rear disc brakes
rear role pan
rear flip license plate
t5 transmission
88 roller 302 with an e303 cam
possible 4 link
center console
4:11.1 axle gears
front sway bar
rear sway bar
f600 cluster
3point seat belts
front disc brakes
hide away hitch
soon to be:
rear disc brakes
rear role pan
t5 transmission
possible 4 link
center console
4:11.1 axle gears
1964 F-100 Custom Cab Short Bed
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
1950 F-1 Original 239ci Flat Head V8 SOLD
1995 f-150 4x4 Swb 4.9L 5-speed FORSALE
My Build:
http://www.fordification.com/forum/view ... &sk=t&sd=a
My Build:
- Craigerf100
lets see some pics 69timemachine69timemachine wrote:My favorite mod is my TKO-600 transmission! Having the overdrive is so awesome!
My Build:
My Build:
just a weather stripping change, and a peek o boo mirror,
Going from the 15x6 rims with 205/65-15 tires to 15x8's with 31-10.5-15's.........now it looks like a truck should....
1997 Honda CBR 900RR
- MadJoe
So far the single best thing I've done to my Bump is replace the points with a Pertronix Igniter. Of course I haven't done much yet, so there's still plenty of time. I'm looking forward to getting the 4V intake and a new carb or EFI installed, and headers, but that's a different budget for a different day.
-Joe
-Joe
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
- 1970F250CS
Sorry, wrong thread.
The only mods I've done have been swapping the 390 w/a 460, from my 86 E250, and replacing the rear drum brakes(3x12) w/the drum brakes(3 1/2x12) also from the E250.
[image][/image]This upgrade is probably nothing new, but here it comes anyway. I have a 1972 Bump project that had a rusted out drivers side inner fender, radiator support mount, front cad/frame mount. I purchased a 1978 f150 4X4 locally for parts. I exchanged the whole inner front clip along with the steering column and the cab support mounts. I would love to hear some more mods like this for some other upgrades. I still have the hood latch system to contend with along with trying to use the '78 wiring harness in my '72. Any feedback would be appreciated.
Thanks,
Kevin
Thanks,
Kevin
- Ranchero50
Diesel swap by far for my use.
