I did get the 79' tilt steering columns turn signal switch wiring graphed into the 71's wiring harness today finally, (all my connections soldered with heat shrink tubing). I had to change the wiring to the rear brake lights at my relay box, (I had these hooked up wrong originally when I mounted the relay box).
The turn signals are working fine-front and rear-via the tilt column prersently.
I'll take some time soon to edit the tilt thread I started with what I've found, (documented wire for wire) on the wiring of the tilt into my 71'.
I have not, (and might not) hook up the 79 columns hazard switch. And I have not completed my horn wiring via the tilt column, (yet I know the horn wiring through the tilt column is good). Really hoping tomorrow ends with the firewall clamp back on the column under the hood, and the column being sealed to the firewall so I can finally drive the truck again.
