started my tank swap
M-100
Re: started my tank swap
Post by M-100 »
Get better soon
emeraldcoupe
Post by emeraldcoupe »
back finally feels better, got the mounting done. made straps, still need to clean and paint and put the rubber isolators in. wound up with 16" of ground clearance. i welded the nuts to the inside of the x members. also mounted the mustang fuel filter bracket / filter
** not sure why the tank looks lop sided, must be the angle of the picture
Fordkid68
Post by Fordkid68 »
Sweet! Glad to hear your back is getting better. Keep up the good work!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
emeraldcoupe
decided to use a ranger fuel door instead, the dent fill tube is larger than the ranger tank fill.
basketcase0302
Post by basketcase0302 »
Looking good! :thup:
Still blows my mind, (I've "preached" the Bronco tank install for years) why anyone could/would even fathom putting the Mustang tank in that requires butchering up the flat portion of the rear bed area, (which also makes hauling anything 8' long a thing of the past). :hmm: :pop:
emeraldcoupe
basketcase0302 wrote:Looking good! :thup:
i completely agree. i hate the filler in the bed floor. i guess if the truck is only a hot rod or a show truck it would work, but not if your going to use it.
emeraldcoupe
been working a ton of ot, guess i shouldn't complain.
got the fuel lines run
emeraldcoupe
no updates, i've been working almost every day. i'll post more progress when i get a chance to get back to it.
1browski
Post by 1browski »
This is another project on my list. I definitely dont like the fuel nozzle in the bed floor. I really like the bed rail ones but not sure if I want to do that but we will see when its time. Looking good on the project.
M-100
Post by M-100 »
I've been following this. I like this much more than the mustang tank . Have you figured out how to get the sending unit to work? I'm doing this also just ordered the tank and pump assembly .
basketcase0302
="M-100"I've been following this. I like this much more than the mustang tank . Have you figured out how to get the sending unit to work? I'm doing this also just ordered the tank and pump assembly .
Not real sure but isn't the Bronco tank sending unit the same ohm resistance? :hmm:
emeraldcoupe
still working a bunch of ot, but i got a few pics to show how the tank fits installed. there is a little more than 15" of ground clearance. i still have to cut in the fuel door.
Terry Veiga
Post by Terry Veiga »
That looks good and seems like a relatively simple install. Any idea how low it hangs compared to a typical Mustang tank retrofit?
TERRY : 1972 F100 Ranger XLT SWB
2WD, 429/C6, A/C, P/S, P/Disc
In His Holy Name
emeraldcoupe
Terry Veiga wrote:That looks good and seems like a relatively simple install. Any idea how low it hangs compared to a typical Mustang tank retrofit?
no idea, but i know the mustang tank is much flatter.
emeraldcoupe
installing the fuel door
