Posting an update!
No tech discussion, please
beejaytx225
Re: Posting an update!
Post by beejaytx225 »
One thing that bothers me a bit is this mounting point for the passenger side I beam.
Do you see how it angles back a bit? I don't know if that is normal or if something hit it in the past and bent it back. I can't find another truck to compare it to.
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Family nicknamed her "Bethany"
Central Texas
sargentrs
Post by sargentrs »
Nope, not normal. Mine were straight and vertical. A few photos of mine, before and blasting my frame are toward the bottom of the first page in my build thread in my signature. Here's a couple of shots I just went out in the garage and took.
beejaytx225
Oh boy... Thats kinda a bummer. :cry: But! I do appreciate the help sargentrs! I guess I'll dive in and see what my options are :lol:
360 w/C6
Peacock Blue
Central Texas
beejaytx225
Looks like I'm gonna have to pull the bent bracket off and either straighten it or replace from a donor truck. After installing new I-beam pivot bushings and radius arm bushings the driver's side beam no longer clears the bracket. Diving into some heavy metal tweaking :doh:
360 w/C6
Peacock Blue
Central Texas
JoshT
Post by JoshT »
Don't know how much of a restoration you are planning, or if you are willing to use fabricated aftermarket parts. If you are you might want to check this out:
https://autofab.com/i-22828666-65-79-f- ... pivot.html
My truck is a 4x4 and I haven't used them. Little expensive, but it's probably stronger than the original and its available if you can't find used.
I happened upon their beam pivots for the I-beam Rangers when searching for something else. I've got a stalled 86 Ranger project truck and one of its beam pivots is worn due to loose pivot bolt. When I found them I saved the link and will be ordering a set for the Ranger if I ever resume that project.
beejaytx225
That is absolutely outstanding!!! Thank you so much JoshT! I was having no luck finding an aftermarket bracket till now :D
360 w/C6
Peacock Blue
Central Texas
beejaytx225
After a thorough review of their website and the Google reviews....part is ordered :) will post pics and updates when I get it :)
360 w/C6
Peacock Blue
Central Texas
JoshT
Post by JoshT »
Please do! I know it isn't the same part I need, but still interested in seeing what you receive and think about it.
Like I said price is a little high IMO, but they are the only ones I've found offering it. If word on the interwebz can be believed, imagine you'll be getting what you paid for.
jzjames
Post by jzjames »
Yep. That was a life saver. 8)
beejaytx225
Received the bracket from AutoFab today. Have to say it's a pretty solid piece. Good welds, thick metal.
360 w/C6
Peacock Blue
Central Texas
beejaytx225
Got the new bracket cleaned, primed and painted. Will be removing the bent bracket tomorrow :thup:
360 w/C6
Peacock Blue
Central Texas
sargentrs
Post by sargentrs »
Can't wait to see how it works out! Good luck!
beejaytx225
Got the new AutoFab bracket mounted. Holes lined up "okay" I'll probably end up welding it to the frame. But super stoked that I can finally get the front axles back on :D
360 w/C6
Peacock Blue
Central Texas
popeyes71
Post by popeyes71 »
Those brackets look great! Looks like assembly of the front end is in the near future. :thup:
-Popeye-
1971 F-250 4x4 Highboy
bellamor
Post by bellamor »
I can see progress with every update that you create on this thread. It seems like the modification process is going well on your end and I can't wait to see how it goes. :fr:
