F250 390 Cam Selection
WhitsEnd
Re: F250 390 Cam Selection
Post by WhitsEnd »
DuckRyder wrote:Let us know how that works, I think its a better choice than a 270H...
Interesting it says it requires adjustable valve train, as I see that as the main benefit of HR vs SR, bolt the rockers down and forget it. Lykins is even cranking out non adjustable roller rockers...
They suggest adjustable valvetrain simply to cover themselves, because it certainly won’t be the same with a significantly different length lifter. To get the right length and geometry, you either need specific (custom) length pushrods OR adjustable rockers. Even with adjustable rockers, you may not be able to get your factory length pushrods to work.
Get an adjustable pushrod measurement tool and you can use your existing rockers. Find the right length with the checker, accounting for preload, and order custom length pushrods with the correct size and style interface at each end (ball/cup).
If you think you will ever go to a roller rocker, I would call Brent and have him hook you up with the non-adjustable rockers as well as the pushrods. His rockers are made by Harland Sharp exclusively for him.
Trend or Smith Bros will ship you what you need and their website will show you how they want you to specifically measure for their system. Some measure actual total length vs. center of ball, etc.
8) 1970 F100 Ranger 2WD
:thup: project link: http://www.fordification.com/forum/view ... 22&t=83642
treverd
Post by treverd »
Sparky,
When I was rebuilding my 390 Stroker, I was in a similar Cam Shaft predicament.
I was told by countless people to call Ken Heard @ Oregon Cam Grinding.
After doing some research on Oregon Cam, I now understand why Ken is highly regarded. They are one of the few remaining custom camshaft grinders/designers here in America. On top of that Ken is a huge FE fan. I believe he has/had a F-100.
I went with a hydraulic flat tappet setup in my 445FE. After interviewing me about engine specs and how the truck will be driven, he selected #1425. I could not be happier, performs exactly how I wanted it to, price was good, overall Ken took great care of making sure I got the right cam.
Hydraulic Flat Tappet - https://documentcloud.adobe.com/link/tr ... c04fea69be
Hydraulic Roller - https://documentcloud.adobe.com/link/tr ... 345e6495fd
http://www.oregoncamshaft.com/
Oregon Cam Grinding, Inc.
5913 NE 127th Avenue #200
Vancouver, WA 98682
Phone: 360-256-7985
