An after thought just hit me as I read the board. .....If you suspect an intake leak on an FE engine......take a 1/2 hour road run at hi way speed if that is possible in So. Cal. ...then remove the plugs & keep them in order with each cyl, SOMETIMES a cyl running lean will show on the plug,
UNLESS it is sucking oel, then it will sill show on the plug , just a different color....look for an off color plug..... Donnie
Late Shifting in C6 After Road Trip
- colnago
Re: Late Shifting in C6 After Road Trip
I live in the high desert. Los Angeles has taken our water, but they haven't overtaken our freeways (yet). Except for ski season; then it's a constant stream between LA and Mammoth Mountain!Donnie wrote:take a 1/2 hour road run at hi way speed if that is possible in So. Cal.
I'll try to take it out for an early-morning sprint on Saturday.
Thanks,
Joseph
