t-case gasket
- eggman918
Re: t-case gasket
I was running 50wt when I rebuilt T case I switched to synthetic 80wt gear lube as an experiment, however the 50wt was in the truck for many moons
Steve.
Steve.
- 1971ford
Re: t-case gasket
So whats needed to swap a 205 in? What can it come out of?
What oil should I put in my 24 for now? Thanks
-Ryan
- averagef250
Re: t-case gasket
A 205 from a 73-77 F-250. 90wt gear oil.
- 70f350
Re: t-case gasket
Is it possible to convert a "married" type 205 to an "un-married" type? Would it be better to install the married setup?
“If everybody is thinking alike, then somebody isn’t thinking.”
- General George S. Patton.
Re: t-case gasket
Different case. Mounting points are different, the married usese the adapter to hold it.
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- mlheppl
Re: t-case gasket
Also the bolt pattern on the tail housing of the NP 435 is different for trucks with a mated 205 transfer case. The bump era F250 4X4 uses a 2wd version of the NP 435. I can't remember which is which, but one has a squareish bolt pattern and the other's bolt pattern is narrower on the 2 bottom bolt hols IIRC. Therefore the mated transfer case will not bolt up to the tranny. You would have to swap out both the transmission and transfer cases to go with a mated 205.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
