FE vs FT
Re: FE vs FT
the full sized oil pans i heard were worth getting from them. i think you also have to use the oil pump tube fo rthat pan fo rthem to work good. i would like to know more about this dist bushing thing and how you can tell if it need one or not. i have a 330 dist sitting here and it look exactly like a fe dist. the shaft looks the same size.
Joshpow
Re: FE vs FT
Post by Joshpow »
If someone needed an oil pan I might, but I won't need it on an occasional use farm truck. Just mostly wondering about the trans because mine has front bearing wear and a bad second gear synchronizer. Won't shift down into 2nd unless you are stopped.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
