float issue? fuel pressure issue?
BobbyFord
Re: float issue? fuel pressure issue?
Post by BobbyFord »
Empty the float bowl, attach a section of clean fuel hose to the fuel inlet and blow into the hose while manipulating the float up and down to see if you can spot anything significant... :hmm:
mad2smile
Post by mad2smile »
i'll try to find some. kinda hard to go to a parts store with no wheels. :)
1976 Ford F-150 Supercab 4x2 w/390FE engine C6 - 76,000 miles
1995 Taurus SHO 3.0L Yamaha V6 MTX w/Quaife LSD - 75,000 miles
2002 Dodge Neon R/T 2.0L I4 MTX - 91,000 miles
1993 Dodge Ram 3500 5.9L Cummins 6x4 Flatbed MTX- 100,000 miles *SOLD*
mad2smile
Post by mad2smile »
alright, i sort-of tried what you said. i set the air compressor regulator to about 8psi, then blew that into the fuel filter on the front of the carb. the needle easily stops the flow of air with minimal downpressure (basically me just touching it). im kindof at a loss here. none of this makes sense. the only thing i though that might be causing this problem is this:
the float rests on a brass rod, which sits in a cradle in either side of the bowl. what if the brass rod is raising higher in the cradle when the float goes up, causing the needle to come out of the seat as well? does that sound possible? and if thats whats happening, any ideas on how to keep the brass rod fully seated?
BobbyFord
Post by BobbyFord »
If I remember correctly, there should be a small stainless steel clip holding the float pivot rod down...
I just looked at your pics. The clip is flopped over to the float. Flip it back over and clip it in the groove at the top of the brass valve seat...
Prolly gotta unclip it from the rod to get it underneath the stainless tab that is over the needle...
mad2smile
Post by mad2smile »
will try. that would be pretty funny if doing so solved the problem.
BobbyFord
Post by BobbyFord »
mad2smile wrote:will try. that would be pretty funny if doing so solved the problem.
That IS your problem.
mad2smile
Post by mad2smile »
yep. i feel like an idiot now. in addition, im pissed because ive wasted multiple days of my life on this. im also quite happy. crazy how something so simple and so small can fix such a major problem. thanks for all the help.
BobbyFord
Post by BobbyFord »
mad2smile wrote:yep. i feel like an idiot now. in addition, im pissed because ive wasted multiple days of my life on this. im also quite happy. crazy how something so simple and so small can fix such a major problem. thanks for all the help.
Don't feel like an idiot. We've all made similar mistakes. This is simply one mistake that you will never forget AND never make again. Glad you got it fixed :thup:
mad2smile
Post by mad2smile »
i tell you what... this whole engine swap deal has been a learning experience. thats for sure. its really nice to finally be running. now for tuning... well, i guess trial and error ought to get me there. :D
thanks again.
This is actually a fairly common problem....quite a few members have posted similar question. Just for future reference, this is the clip you need to be sure you've got properly installed. Otherwise, the floats will lift the shaft...and bring the needle valve with it, meaning it can't stop the flow of fuel when it's supposed to.
mad2smile
Post by mad2smile »
thats a very nice, clear illustration. do you have one of those for every truck part? :lol: thanks.
thebannister8
Post by thebannister8 »
sometimes mistakes are the only way to learn...but it's a tool in your toolbox to help the next guy ( or gal )... :drive:
