Raise the float level and test drive it on the freeway to see if the stutter goes away- that may help your low end problems, too.
Joe
crappy throttle response, hesitant
Moderator: Ranchero50
re: crappy throttle response, hesitant
There's only 3 sure things in life: God, Death, and Ford Trucks.
- 71-F-250SC-72-F-250C
The points condensor has also been replaced.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
[quote="ToughOldFord"]
72 f-250 Custom
03 mach1 mustang
- Commodore Woods
Don't know if this would apply or not, but I know on my '72 390 I've got a bad vacume leak around the main rod in the Carb, old bushings. Maybe check and see if you've got any play in the rod?I can hear a vacuum leak but the gauge say's it is running fine
'72 F100 Ranger XLT 390 V-8, C6 Trans.
"You can lead a man to knowledge, but you can't make him think"
"Hear and see all evil, Document such evil, speak it at the correct time" IOW Cover thy A$$
- 68F250
You definitely have a vacuum leak somewhere, I'd put money on it.
Take some starting fluid and while the engine's idling spray all the vacuum hoses, fittings, carb. base, throttle shaft, even around the intake to head surface. If the engine picks up speed you've found it. Don't stop at the first one. Be very specific on what you spray, don't go fogging. The carburetor will suck it up and give you a false indication.
Also, disconnect and plug the vacuum line that goes to the vacuum advance. Do you have power brakes?
Barry
Like JDS, I would check the float level or fatten up the mixture by changing the jets. I'm not too faniliar with the 2bbl, but it definitely sounds like lack of fuel.
Come to think of it, when was the last time you changed the fuel filter?
I am gathering up all these suggestions, and plan on testing them this weekend. I was thinking a lack of fuel also at first, and tried changing the jets, but the guy said if I found some jets that would fit in that carburator, to give him a call because he has been looking for years. My only other option with the jets would be to drill them out, which I am not comfortable doing. Also, if it is a lack of fuel, then that can be adjusted out, unless the carburator is just to small for the engine. I know there is a vaccum leak somwhere though for sure, just a matter of finding it. But do you guys think 350 cfm is enough for that engine?
Stephen
Stephen
72 f-250 Custom
03 mach1 mustang
72 f-250 Custom
03 mach1 mustang
Lot's of V-8's run on 2 bbl carbs. I wouldn't worry about cfm's unless you're looking for more power!
