Autolite-2100
- binder56jd
Re: Autolite-2100
now serving #235
now serving #235
Re: Autolite-2100
There is also the universal 2300 series.
http://store.summitracing.com/egnsearch ... 4294902720
I would think that the pick a part yards would be littered with 4v intakes for small blocks, should not be that difficult to turn one up if thats what you want.
- peanutman
Re: Autolite-2100
binder56jd wrote:hey P--what's up mon???
Not much, just trying to waste some more of the wife's money. I need to come over and see you guy's. I have been busy with my ride.
http://store.summitracing.com/egnsearch ... =sku#rstop
1970 302,ps, ac, 3 speed o.d.
- peanutman
Re: Autolite-2100
Thanks for the links guys!
- binder56jd
Re: Autolite-2100
now serving #235
now serving #235
Re: Autolite-2100
Hey P-man. I got my Holley 500 cfm 2bbl from jegs for 269.99. You can go here http://www.jegs.com/p/Holley/743827/10002/-1 and take a look. Again the best thing I have put on my truck. I still think there is nothing better than a brand new carburetor.
Corbin
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
- peanutman
Re: Autolite-2100
Thanks green, i will probably go that route. May mess w/ the 2100 a bit. Thanks for the info. Sounds like all that's had this prob and went w/ holley it resolved it.
Robbie
Robbie
Re: Autolite-2100
Yeah is a great carb for the money. You will be happy with it.
Corbin
Corbin
- willowbilly3
Re: Autolite-2100
green68250 wrote:Hey P-man. I got my Holley 500 cfm 2bbl from jegs for 269.99. You can go here http://www.jegs.com/p/Holley/743827/10002/-1 and take a look. Again the best thing I have put on my truck. I still think there is nothing better than a brand new carburetor.
Corbin
Re: Autolite-2100
Peanutman I rebuilt my 2100 this evening for around 25 bucks including Berrymans B-12 carb cleaner.Had to replace the choke pulloff as well which wasnt in kit.My choke was staying on all the time and would idle up to 2000 rpm in this cold weather when warm,had to keep kicking pedal to get her to idle down.Was also getting a whopping 10mpg which just didnt seem right
Truck started right up and idles great now just take your time and follow the setup directions and should get you in the ballpark.Tommorow i'll get the vacuum gauge out and set the timing as well.I believe you will find the 1.08 numbers on side of your carb which should be around 390cfm.
As to the heat soak issue I would think it is a lean condition caused by either carburetion or timing being advanced.I had this same problem with the Holley on my 86 Super duty with 351HO and factory Holley setup.Had just bought a 26' fifth wheel trailer and was dragging her home and she would just run oughta oomph.Got the rig home by buying a bag of ice and sprinkling a little ice on intake around carb every time it would act up.Turns out it was a little crack in the electronic ignition module in the dizzy that would open up when hot and cool off and run fine when cool
Lon
71 F100 302 T89OD
90 Mitsubishi Montero SWB
94 Tbird Sport 4.6L
86 F250 Super Cab S/D 351W H/O C6
01 Mitsu Montero Sport
71 F100 302 T89OD
94 Tbird Sport 4.6L
- peanutman
Re: Autolite-2100
Thanks for the tips bc.
