Do stock 302s have the trapeze throttle linkage
dablack00
Re: Do stock 302s have the trapeze throttle linkage
Post by dablack00 »
Joshpow wrote:My only thought is the incorrect engine block would stand out as bad as a throttle linkage to a trained eye. The casting numbers would tell all.
How is a 71 302 in a 71 F100 wrong? I will have the correct engine, carb, everything. Everything will be stock. :?
Hawkrod
Post by Hawkrod »
I want to meet the guy who can determine the wrong block on a 302 when it is installed! LOL The casting numbers are above the starter and can't be seen without removing it. If we were talking about something special then you could see a difference but early small blocks are pretty hard to tell apart even to the trained eye. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
70shortwide
Post by 70shortwide »
ill work on those pics. shoould be able to get them tommorow. i think he used the 302 brackets, they were a little different. pretty sure he just made them work. ill ask. the 'trapeze' is already ont the shelf, so i cant get pics of it installed
willowbilly3
Post by willowbilly3 »
The 302 one mounts different. I think I have the base for one somewhere if you need it. Mine was broke when I went to get the crewcab and the only one I found was a 302 and would not bolt on the 390 so I used the parts off it to fix mine.
I don't use one anymore but I still have a collection of them.
Joshpow
Post by Joshpow »
Sorry, I didn't realize the new engine was the correct year. As faras the guy finding them after installation, never underestimate the power of a determined redneck. I'm sure where there is a will there is a way!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
papabug71
Post by papabug71 »
Anyone got a picture of this trapeze linkage?? I guess I have never seen it.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
heres one from a 360
papabug71
Post by papabug71 »
Hmm. Never seen that before. It looks like alot of trouble!
Matt
Mine since 5/7/'94
they really are a simple thing. most guys have trouble with them when they go to put holleys and eldebrocks on. the throttle linkage needs to got the oppisite way of the trapeze so they get rid of it for just a straight rod.
Dragon
Post by Dragon »
The trapeze on one early T-bird I saw was how the tranny kick down worked. It came to the trapeze and stopped. I don't know what tranny and it could have been a 61-63 bird if I remember close.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
