intake manifold gasket ?
- FORD428CJ
Re: intake manifold gasket ?
I agree with Dragon. I don't use the end gaskets! Good old silicone works best for me. Let it sit for 10 min and then install the intake. JMHO
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
What would work better on a factory Ford 2x4 aluminum intake manifold? I,ve not had any luck using black rtv.Should I be using the cork since its a factory intake? Thanks Brian. ![Confused :?](./images/smilies/icon_confused.gif)
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
95 Ford Lightning
38 John Deere G
- Dragon
Personally I hate cork. The real good gasket sealers will tear it on removal and if left in place for anytime cork will slowly weep (suck) oil to the outside.
Get FelPro http://www.partsamerica.com/productdeta ... 02&PTSet=A
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.![Smile :)](./images/smilies/icon_smile.gif)
My Gallery
Spark test
My Gallery
Spark test
- SteveC
i used "the right stuff" when you use that stuff you have to be ready to put the intake on cause in around 5 minutes that stuff sets... and when you put the intake on its best to have help or a hoist you DO NOT want the intake to slide front to back if you miss getting it set down carefully lift it a bit and move it.
that is what i have learned on fe moters as far as intake gaskets go.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
yea the cork front and back gaskets aren't the ones to use. get the rubber ones that sit over the front and rear block ridge. then use silicone in the corners of where they meet the intake gaskets.
I am not aware of anyone making the rubber end seals for an FE, those do work great on Small Blocks at least for me.
- Dragon
The link I put up above for Fel Pro rubber.DuckRyder wrote:I am not aware of anyone making the rubber end seals for an FE, those do work great on Small Blocks at least for me.
To keep the manifold from sliding front to back slip the dizzy in and use it as an alignment tool so the manifold does not slide while you are trying to get the bolts set.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
Oh yeah I have had those, don't like them, they aren't really what I think of as quality rubber... sort of like Fel Pros "rubber" valve cover gaskets.Dragon wrote:The link I put up above for Fel Pro rubber.DuckRyder wrote:I am not aware of anyone making the rubber end seals for an FE, those do work great on Small Blocks at least for me.
Oh well, you guys keep using Fel Pro and silicone, I'll keep using Victor and cork...
