Cardone booster for '67: Updated - please help!
- kilog55
yeah the original m/c non power brake seal will not work it is way too small i tried it
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
because the gasket he is talking about molds around there rear of the master. and the hole in the firewall is larger than the rear of the master hole. it has to be a tube like i showed the pic of to work. the tube goes from the booster to the firewall. it takes up space from the booster brackets to the firewall.
- kilog55
yeah i thought it would work since you cant see any visible gap with the old unit but i was wrong.
but yeah the part fordman showed'll work
- Supermike
re: Cardone booster for '67
Why is it that it seems I'm discovering another part I "need" like every other day in trying to upgrade to power brakes?
Do I really need this "brake booster vacuum tee"? Or should I already have one on the truck? (the one below is fordman's auction):
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0208644978
Also, under the possibility that I DO need this and I do NOT win the auction for Craig's part, where else do I score one of these?? Do they make them aftermarket, available at parts stores?
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
- kilog55
there should be a vacuum line you can tap into with a regular T fitting never seen a 352 in person so i couldnt tell ya where one may be. but you have an auto so you should have one on there.
- seattle67
Mike,
I mentioned it in my original post, but all I did was buy a "T" and spliced into the vacuum line going to the transmission. Since you have an auto transmission, thats all you should need to do to.
Something like this
Something like this
Dan
- seattle67
That one in the picture, you can break off the smaller sections until you get to the size you want to use. But that one was just an example to give Mike an idea what I was talking about. Any parts store should have a 3/8 tee.
Dan
- Supermike
Okay folks... I think I have everything!
I have the Cardone booster and MC for a '67 (part #50-3514), I have booster brackets that have been bead blasted, primered, and painted, I have about 3' of vacuum tubing (went for more than I need on purpose), I have a 3/8" "T" fitting like the one shown above in seattle67's post (could only find white, though). I have hose clamps, of course.
I wish I had the little bracket that holds the tube to the firewall, but I guess I can use a ziptie or something.
So... is there anything else I need, aside from brake fluid? There's no special brand or type of fluid I need to use, is there (outside of "brake fluid")?
