Im confused. The "ear" on the column rotates, correct? So between that rotating somehow the rod moves back n forward to shift.
I think.
EDIT
I think what I need is calld the "bell crank assembly" and the shift rod.
C6 install
- OldRedFord
re: C6 install
Here's mine... note the bend is less thsn fordman's and has a threaded adjuster.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
'72 F250 Ranger
- basketcase0302
re: C6 install
Nausea,
That is different, (never seen one with the threaded end like that). All my dents looked like Fordmans, (and had no adjustment) which would be nice.
Basketcase
Basketcase
re: C6 install
Some of the later model trucks used a bell crank set up on the automatic trannies.
Just hit the junk yards for the parts you need.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- OldRedFord
Re: re: C6 install
So on the bumps there was no bell crank set up, just the one rod?cdeal28078 wrote:Some of the later model trucks used a bell crank set up on the automatic trannies.
clint
Hows the shifter on your C6 set up?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
