OT: 95 f150 shudder diagnosis
re: OT: 95 f150 shudder diagnosis
change to mercon dextron 5 and put dr shudder in and that will take care of the problem for awhile md5 is full sentric but in the near furture you will have to put a new torque converter in or it will shell the whole tran
I have a 95 F150 work truck with a 300-6 and automatic and it is having tranny issues also. The u-joints have been replaced already, so I have ruled that out. Even with the overdrive button in the off position it shifts really hard when it changes gears at about 40mph. I thought that it would go through 3 shifts only with the overdrive locked out, but it feels like its making a 4th shift and comes in so hard it almost snaps my neck. Is this the torque convertor locking/unlocking? In town I have started running it in second gear so it does not make the hard shift, but I figure this can't be the best thing for the tranny. Is this also an indication of a convertor going south?
When my truck grows up, it wants to be a Crew Cab like Teacherman's
- averagef250
Had a 95 T-bird with the infamous torque convertor shudder. Started soon after we bought it. Changed the fluid to the Mercon IV, added Mr. Tranny shudder fix from NAPA and added a bigger cooler. Drove the car about 40k more miles without a shudder. Sold it
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
i got mine shudder fixed today. i used a fluid modifier called drtanny. www.drtranny.com
it took the shutter out of my transmission. i got on the highway and it didnt shutter at all. either on the way to work or on the way home. i got it from oriellys. its a little tube about 6 inches long.
