Good Price For A Steering Column
GMan
Post by GMan »
Thanks very much.
l1k2gadd
re: Good Price For A Steering Column
Post by l1k2gadd »
I went to the wrecking yard when I needed to fix my 1968 F100 with a three-on-the-tree manual tranny column in it. I found a '72 SWB StepSide Bump in the wrecking yard and since the cab looked the same as my truck I pulled the column to put it in my pickup. It went right in.
I used the '72 steering wheel and other than a gap between the wheel and the column it worked fine. When I found an original steering wheel in a '71 (I believe) I got it and brought it home from the wrecking yard. I swapped the steering wheels. When I went to put the horn button from the '71 on the '72 column the center shaft was too long and the horn button wouldn't go on the steering wheel. The picture of the black wheel with the red highlights on it tells it all. I went back to the wrecking yard and got the '71 column too, now. I'll swap it out some day.
Yes, the one is an automatic column, BUT the '71 column looked the same way when I pulled the steering wheel off of the column in the yard, before I knew I needed the center shaft too.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
GMan
Post by GMan »
Thanks for the added info.
G
MadMaxetc
Post by MadMaxetc »
Yep, you just have to cut off the parts above the threads to make the newer shafts work with the old wheels.
Dan
FORD Girl
Photobucket Pictures
sargentrs
Post by sargentrs »
Shift handle and blinker look chromed. That would make it 69+ wouldn't it?
sargentrs
Post by sargentrs »
oops, my bad. 3rd pic shows it's obviously painted. I'm just going sit back, shut my mouth and lurk. :oops:
