problems starting in 1st....
layedout72
Post by layedout72 »
i think it ended up being a little of everything. im sure the clutch could use atleast a cleaning....but I can't afford a new one, and really don't want to pull the tranny for that alone. IF the clutch goes out....I will replace it when I can. It shifts fine though, first to second, second to third, into reverse, its all smooth. I drove it a little this morning after putting the hose that recirculates back into the carb spacer, and then plugging another line on the carb. does fine now.
i do wonder about the vaccuum advance though....it's not hooked up. what will this do for me?
MadMaxetc
Re: re: problems starting in 1st....
Post by MadMaxetc »
fmartin_gila1 wrote:You might also check your motor mounts and tranny mounts. You could have broken springs in the clutch disk itself. These will give you chatter too.
Fred
:doh:
I had the same thing on the first clutch I put on my 302. A spring on the Disk and one on the pressure plate broke. It was a reman from NAPA. I took it back and got NEW one and it was fine.
Dan
FORD Girl
Photobucket Pictures
AustinTom
Post by AustinTom »
Is it the original tranny in the truck or one some previous owner pulled out of a car and stuck it there?
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
