Tranny swap??
AustinTom
Post by AustinTom »
To pull them together you have to pull the top cover of the tranny. I did this and put a heavy duty trash bag over it, used duct tape to seal that up and went from there. No dirt in the transmission. Just be very careful and don't rush it, everything will be fine.
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
Jason67F-250
re: Tranny swap??
Post by Jason67F-250 »
Here is my :2cents: I would drop the tranny first then pull the engine it sounds like more work but so does pulling the front clip. Either way you go good luck and have fun.
AustinTom
Post by AustinTom »
It is much easier to bolt a tranny to a motor if the bellhousing is on the tranny but that isn't very easy if is motor is in the truck
95 F-150 lwb 4x4
