#02 - Jan. 22, 2007
- xxxtina63
re: #02 - Jan. 22, 2007
I was thinking it looked a lot like the clip that holds together the heater hoses running to the heater core?
My FORDification Photo Album
- Sharkdance
Thanks chips68. I was sure that I am right. But..... Now Im second guessing myself.
I went back and re-read what Keith posted about the part.
He said its "on all bumpside and dentside trucks"
While Im sure I saw that exact clip holding the steel fuel line to the gas tank on my bump, the dentsides had the tanks under them. Not in the cab. So I dont know where (if at all) that clip would go on a dentside.
- chips68
Well, like Sharkdance said a dent don't have the tank in the cab, However I removed a tank from a 72 two weeks ago and it had the clip holding the line to the tank and this one (maybe not orignal) did not have a rubber coating. But like I said who knows if thats factory installed
- hoss103
Cool, I'm a wiener!
How 'bout 60-40?That is what I think it is.If you are right hoss103,you have to share half your winnings with me!
Carl
'69 F100- 302, 3-on-the-tree
'04 F-350 SRW PSD
'04 F-350 SRW PSD
- 71 LONG BED
Re: re: #02 - Jan. 22, 2007
Keith, I'm going to double check, but I'm almost certain that there were clips just like this one holding the steel fuel line on the frame under the motor. And also on the steel vent tube that runs on the other side to the charcoal canister. I'll check into it and let you know if I'm remembering correctly.FORDification wrote:I also believe that any clamp that held wiring, brakeline or fuel line was either plastic or a metal clip dipped in liquid rubber...I don't think they used a straight metal clamp on those items, to minimize chafing.
John Member #1549
I know that the steel fuel line that runs along the frame is held onto the side of the frame by plastic clips, there are no steel clips along that at all. And fordman verified that the in-cab tank does use one of these clips on the line that runs down along the side of the tank, but the clip isn't plain steel, but lined with plastic. However, if you could check what holds the vent tube line that goes to the charcoal canister, that would be great.
- kknip
OK!hoss103 wrote:Cool, I'm a wiener!
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
- 69F110
- 71 LONG BED
I was a little hung up last night, had to run out and pick up something for two-bit.FORDification wrote:...if you could check what holds the vent tube line that goes to the charcoal canister, that would be great.
John Member #1549
- jeepermc
Holy old threads batman..... but my 75 dentside 4x4 has a in cab tank..... maybe itsa canadian thing?chips68 wrote:Well, like Sharkdance said a dent don't have the tank in the cab, However I removed a tank from a 72 two weeks ago and it had the clip holding the line to the tank and this one (maybe not orignal) did not have a rubber coating. But like I said who knows if thats factory installed
1952 CJ-3A- 289cid, NP435
1969 F-250 4X4- 410cid, NP435, Dana 24-44-60LS , 4", 36's
1975 F-250-Ranger XLT 4X4- 390cid, NP435, NP205, 44F, 60 rear
1987 Mustang GT
New addition- 1997 F-350 PSD std. cab 4x4
I really have a problem...............
1987 Mustang GT
The F250 4x4s also had them, up through '77-1/2...since they still had the narrow frame spacing, an aft-axle fuel tank won't fit.
