67 disc conv.??
jguajardotx
re: 67 disc conv.??
Post by jguajardotx »
Have you tried using the the pitman arm off of the 79 f150?
From what i understand that is the way to go. :thup:
Re: re: 67 disc conv.??
bmerkley58 wrote:I have the Bendix power steering box on my 67 and have the disc brake set up from a 79 F-150 and have tried both the Bendix pitman arm and the Saginaw pitman arm on the Bendix box and have a problem with the steering box running out of travel before the spindle stops hit the I-beams. The spindle lacks about a 1/4 inch on the passenger side and about a 1/16 inch on the driver side from hitting the I-beam when the steering box is turned lock to lock. I think this could be a problem and I haven't decided what to do about it.
Any ideas?
That's not a problem with the steering linkage, it's a difference in the lock-to-lock limits of the box itself. The Bendix box has a smaller limit than the Saginaw box. I have those specs around here somewhere, I'll see if I can dig them up.
my 67 has a bendix box on it. it also has a bracket that is a stop for the pitman arm to stop its travel in both directions. this is original to the truck as far as i know.
jguajardotx
re: 67 disc conv.??
so will there be a problem with the pitman arm using the 79 150 donor on my 67 i hear some yes some no i want to get started but still confused?????
mljjones67
re: 67 disc conv.??
Post by mljjones67 »
Man i wish I knew more to help you out!
