Dropping the '69 tomorrow
Randy Beck
Re: re: Dropping the '69 tomorrow
Post by Randy Beck »
John McGaughey wrote:The truck looks great. Did you hit any snags along the way? Would you do anything differnt if you had to do it again. I'm planning on lowering one of my short beds next spring so any words of wisdom would help.
John
I would sudjest that you don't use the tie rod relocators from the DJM kit. You can't get a wrench in the relocaqtor to tighten the castle nut tight. Just by looking at pics, The AIM relocators look kike they are alot better design. That's my 2 cents worth.
1969 F-100 Ranger
351W/TCI Streetfighter C6-2800 stall coverter
Proline 180 heads
TorkerII intake/780 Holley
Sanderson headers/Flowmaster mufflers
Best 1/8th mile E/T 8.55
Best 1/8th mile MPH 85.024
mk
Post by mk »
Keith actually mentions that very thing in the 'dropping trucks' tech article. The truck looks good, Randy. I'm dying to do this to my Merc. Did you swap master cylinders or at least take the residual valve out of the front circuit?
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
Randy Beck
MK,
I replaced the original master cylinder with a new MC for a '73 F-100. I also used a power booster and the prop valve from a '73 parts truck
1969 F-100 Ranger
Proline 180 heads
boots
Post by boots »
Nice man, really lookin good.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
green70
Post by green70 »
i took a grinder to a wrench in order to tighten the tie rod end,havent had any problems with the djm set up,be carefull if you decide to cut your springs,1 coil can give a pretty big drop,i would start with a half coil,you can always cut again but you cant put it back..... :2cents:
71 LONG BED
Post by 71 LONG BED »
Won't it hook up better with a little squat in the back? That's the way they did it in the 50's & 60's.
The truck looks great! It will look awesome leveled out too. I was just making a point, pleas don't be offended. :D
John Member #1549
Image Image Image
SMF Speed&Custom
Post by SMF Speed&Custom »
Randy, when you took your springs out did you just use a jack and let them down slowly or did you use a spring compressor? I have stock springs in my 66 but for some reason it sits a bit lower than stock already but the camber is still too positive. I think a half a coil will solve my problem, I might go one whole coil. Sorry, not trying to take over your thread here.
Randy Beck
I jacked up the front end by placing the jack under the big crossmember under the engine. Removed the tires, unbolted the shocks at the top, removed the big nut at the bottom of the spring that is inside the coils, then removed the spring clip that is at the top of the spring. Once all of that was loose, I just pushed down on the i-beams and it falls right out. Just watch your toes, them darn coils are heavy!! :cry:
1969 F-100 Ranger
Proline 180 heads
SMF Speed&Custom
So there is no tension on them when jacked up by the main crossmember? So no worries on a flying spring at my face huh? :D
theskytoucher
Post by theskytoucher »
FYI That hurts real bad!!! I leaned that one from experience.
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
71 LONG BED
SMF Speed&Custom wrote:So there is no tension on them when jacked up by the main crossmember? So no worries on a flying spring at my face huh? :D
When I took the front suspention off of a '73 to get the disk brakes, I was afraid of the same thing. My father in-law insured me it wouldn't and he was right. Nothing happened. The spring just fell out.
John Member #1549
Image Image Image
lightning_msd
Post by lightning_msd »
how much did that cost you for all of that with shipping, and the disc brakes? i would love to do that to my 67, ive been thinking about bagging it but im not sure. any suggestions?
marz68
Post by marz68 »
The only suspension that you should worry about the spring shooting out is one that has upper and lower control arms.
71 LONG BED
When I put the lift on my Cherokee, I almost lost one!! :eek: Kind of scary....
John Member #1549
Image Image Image
ezernut9mm
Post by ezernut9mm »
truck looks good! so how was djm to order from? are they tech savy or just phone jockies? i'd like to get a set of shackles. i would guess they are a 2" drop by themselves judging by the part no.
