Fuel Injected 302 and AOD Swap Questions
I am swapping a Fuel injected 302 and AOD into my 70 F250. The donner car is a 1988 Mercury couger. The car is complete and runs and drives. I have mostly everything worked out, exept what to use for the Accelerator pedal, Accelerator cable, and the speedometer hook up. Any ideas on junk yard parts or any companies that offer aftermarket related items would be greatly helpful.[/b]
- binder56jd
re: Fuel Injected 302 and AOD Swap Questions
lokar http://www.lokar.com/
now serving #235
now serving #235
- SVT522
I used a spare pedal I had for my 73 Mach 1. A 1988 T-Bird throttle cable from a car with a 5.0 worked on the Mustang EFI I put in my truck.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- binder56jd
mini-hijack -- SVT -- What was your fuel tank remedy?
now serving #235
now serving #235
Carter Fuel pumps make a aftermarket inline High pressure pump, for swapping to EFI. I plan to mount it on the inside frame rail under the cab. High pressure pumps are better pushers that pullers. The closer I have it to the tank the better. I just hope it not too loud, mounted under my seat.
thanks for the pedal Idea.
- mercman1953
The Lokar cable will work with your stock pedal. You will have to do something with the end on the pedal. The Lokar cable will have a ball on the end for the pedal and an aluminum clevis for street rod type pedals. You will have to check to see if the ball on the inner cable is big enough not to pull through the pedal end. Go ahead and spring for the mount for the carb that the cable will attach to. It is the best way to do it once and not look like you pieced it together. Lokar also has a TV cable for the AOD that will work with that bracket and is adjustable.
1968 F250 longbed 2wd.
Late model 351w c6 trans.
1969 F100 Explorer
360 3spd manual
1967 Fairlane wagon
302 c4 trans
1969 F100 Explorer
360 3spd manual
1967 Fairlane wagon
302 c4 trans
- mercman1953
1969 F100 Explorer
360 3spd manual
1967 Fairlane wagon
302 c4 trans
1969 F100 Explorer
360 3spd manual
1967 Fairlane wagon
302 c4 trans
- marz68
