my bed
re: my bed
the dent is bigger than that. you think i should heat it up and she if it start getting start when hit it then filler it in?
- 72hiboy4x4
- 460 crew
Just finish beating it in and make yourself a stepside?
- studdmstr
Re: re: my bed
Say what?edgar wrote:the dent is bigger than that. you think i should heat it up and she if it start getting start when hit it then filler it in?
- rjewkes
whoa slow down wheres the Fire?
Ok first NPD has sides that are Made from A mold taken of the entire side of the truck. This will look horible.
where is the dent? If it is low enough you may be able to bring it almost flush. Get rid of the high spots with some grinding and use a thin layer of bondo. Chjeck witha parts house, O'reily, Kragens, Napa or even Autozone. They might have a manual based on auto body repair.
fuelly.com
fuelly.com
