flex-o-matic leaf bolts
- tybob81
On my 68 it has the flex-o-matic rear suspension and for now since its time to start putting everything back together after sandblasting and paint. I wanted to put new leaf spring bolts in it because during tear down the bolts threads were damaged. So I thought it was no big deal I'll just chase the treads down with a tap and die, but the bolts are not a standard size. Bolts from TSC and even LMC are to big. Any suggestions?
re: flex-o-matic leaf bolts
Take a micrometer or a decent set of outside calipers and measure the bolt's thickness. Off the top of my head I don't know why they'd be anything special.
- tybob81
i bought the bolts from LMC for a non flex-o-matic and they are to big it is a odd ball size bolt not a standard 3/8, 1/2, 5/8 size its in between
- tybob81
they dont make the bolts for the flexo and the guy at lmc said these should work.
- tybob81
i just went junk yard shoping and got some extras. My buddys junk yard is full of old ford trucks but only one had the flex-o so i got the bolts out of it.
