Differential (Pumpkin) Leak
71Ford
Post by 71Ford »
I noticed some oil on my driveway from I guess the Differential....it has grease/dirt caked on it where the drive shaft attaches(could that be a bad seal or something?).....how do I check to make sure I have enough fluid to continue driving it????? I seem to remember my old chevy had a place on the back of the pumpkin to add more...I don't see any place on my Ford..
Thanks
Shawn
http://www.fordification.com/galleries/ ... p?pos=-851
71 XLT RANGER ->203,000+MILES/NOT REBUILT
99 GMC 4x4 Suburban, 94 Saturn 200k, 03 Chev Venture
heep70
Post by heep70 »
You got a 9" right? I believe the fill plug is on the side of the diff. Kinda behind the drive line and in front of the axle tube.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
yea its probably the seal. it can be replaced. and the fill check hole is on the drivers side of the 9 inch rear end
390Nut
re: Differential (Pumpkin) Leak
Post by 390Nut »
:yt:
A 3/8th's drive ratchet with a 3" or 6" extension on the drivers side of the housing. Fill with gear oil till it starts to come out the hole.
Quickest way to tell where it is coming from is to clean the housing thoroughly, then drive it for 10 minutes or so. If it's the pinion seal (behind the driveshaft yoke) it will be quite evident. Likely what it is, too, if it hasn't leaked before now.
Paul
`69 F100 390 4spd driver
71Ford
Post by 71Ford »
THANK YOU ALL VERY MUCH!
YOU GUYS ARE GREAT! I WISH THERE WAS A TOWN MADE UP OF ALL THE MEMBERS OF THIS SITE....EVERYBODY IS SO HELPFUL AND NICE.....WE COULD NAME THE TOWN UTOPIA....OR TAKE OVER THE EXISTING ONE IN TEXAS. :lol:
SHAWN
mrsnicks
Post by mrsnicks »
:yt: What they said... to check the level just put your finger in the hole and you should feel fluid just under the hole level. That's how I've always been told to check it. I had a similar leak on my highboy and found out that it was the pinion nut not being fully tightened.... Once I tightened it up the leak went away. Damn previous owners...
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
