Greasy rear drums
phoelsch
Greasy rear drums
Post by phoelsch »
I was replacing my U-joints last night and when I was under my truck I noticed, what I thought at the time, brake fluid all over my rear drums and on my tires. When I removed the wheel and drum it was actually grease. I don't have a clue where it may have come from. It was all over the inside of the of the drum. More on the rear left than on the right. Any thoughts?
kentdaryl
re: Greasy rear drums
Post by kentdaryl »
Gear oil maybe?
studdmstr
Post by studdmstr »
You've probably got rear axel seals that are leaking.
Galaxie64
Post by Galaxie64 »
My money is on axel seals.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
:yt: thats where it comes from unless you been driving through grease.
