Thoughts on LMC bucket seats
Anyone using LMC bucket seats in their bump? My bench seat is pretty worn out, so I've been thinking its LMC buckets and mounting brackets vs reupholstering the bench. I'm leaning toward buckets right now. How is the LMC buckets fit and quality? Do they sit too high, too low or just right? Anyone's general thoughts appreciated. Thanks!
Re: Thoughts on LMC bucket seats
Here is a pic of the truck just because...
My '67 had buckets, but a previous owner put a bench in, I will switch it back someday.
The factory buckets were Mustang seats, they have a very thin back, anything with a thicker back will push the seat foreword, and a Bumpside has tight leg room to begin with, A higher back will do the same. This Forum has a PDF available, to make your own brackets, if your fabrication skills allow it, you may be able to tweak it for higher or lower seats, however the tank and back window will not allow it to be set back much.
F. Noble, Saskatchewan.
