1972 Brake Booster
wolfyboy
1972 Brake Booster
Post by wolfyboy »
I am looking to replace the brake booster and reservoir on my 1972 f250 which has front disc and rear drums. Which vendors are recommended and what model and I should replace these with. I have seen some posts that discuss using the f350 booster, is this an upgrade that I should consider or just get the same style I have?
Thanks for any help
Jim
Re: 1972 Brake Booster
Look under the dash if you have a solid rod its difficult to find one, if its an adjustable rod they can be had but quality is questionable.
Google "Booster Dewey" might be your best bet for non junk. I think i have some detail son making one work in my project thread...
