How to post pictures on the forums
Comments, suggestions or site/forum assistance
OK, so you want to post a picture on the forums, but you don't want to attach them using the Attachment option, or you simply want to have them appear in the thread inline, rather than including a link to them.
Here's how it's done:
First of all, to get a picture show up inline in a message, the pictures HAS to already be online somewhere, not on your computer. If the picture is Ford truck related, you can post it in your FORDification.com Photo Gallery. Alternatively, there are many different image hosting services (like ImageShack) who can host images for you. You simply sign up for an account there and then upload your pictures. The important part is getting the pictures off your computer's hard drive and onto a server somewhere on the internet where they can be accessed.
OK, you've got your pictures on an internet server, and now it's time to display an image in the forums...
All pictures online have a URL...an address, in other words. You need to have this URL. The URL needs to be for the picture itself, NOT to the webpage showing the picture. A proper URL will start with 'http' and end in one of the following 3-letter extensions (listed in order of preference):
Also, the URL cannot contain any spaces.
OK, let's practice. Down at the bottom of the front page of FORDification.com there is a website banner.
Let's try to get this to show up in this post.
STEP 1
First of all, you have to get the URL for the picture, so here's what you do. Right-click on the image, and a pop-up menu will appear:
I'm using Netscape for these screencaptures, so the actual items in the pop-up menu may differ depending on what browser you're using. If you're also using Netscape, you can simply choose 'View Image'. (If you're using a different browser, skip to Step 3.) When you do so, the image itself will show up on-screen all by itself.
STEP 2
You can see the image's URL at the top of your browser. Place your cursor at the front of the URL and drag across it to highlight the entire URL, as I've done here:
Then on your keyboard hit Control C (which is the Copy command), and the URL is now copied to your computer's clipboard. Now skip to Step 4.
STEP 3
If you're using another browser that doesn't have the 'View Image' option, like Internet Explorer, you can choose 'Properties' from the pop-up menu, as I've done here:
When you choose Properties, you'll get a pop-up window that shows the image's URL, and will look something like this:
Sometimes, if the URL is long, you won't be able to see the entire URL, but you can put your cursor down to the lower-right corner of the box and drag it to the right, to stretch it out so the entire URL is visible, as I've done above. As you can see, I've highlighted the 'Location' of the image in this window, by placing my cursor at the first letter and then dragging it across the text until the entire URL is highlighted. At this point, I can hit 'Control C' on my keyboard (which is the 'Copy' command) to get the URL copied to my computer's clipboard. You're now ready to continue to Step 4.
STEP 4
Now that you have the URL for the image to be posted, you're ready to insert it into your forum post.
Let's first just paste the image's URL to the post. Hit 'Control V' on your keyboard, which is the 'Paste' command. Your post will look like this:
You should now see the URL pasted into your message box. If you were to go ahead and just hit the Submit button, the URL will get automatically converted into a link, and long URLs will get automatically shortened to prevent long URLs from stretching the window sideways, but it'll still be an active link:
However, you want the image to actually appear inline, and not have it be a link. Therefore, you need to tell the forum software so...by inserting a 'Begin image' tag at the beginning of the image's URL, and an 'End image' tag at the end of the image's URL.
Once you have the 'begin image' tag:
at the beginning of the URL, and the 'end image' tag:
[/img]
...at the end of the URL, when you hit the Preview or Submit button, it should now show up!
There's a few final things you need to be aware of.
1) Some websites don't allow 'hot-linking', which is the practice of posting an in-line image using the image URL from that site. Other sites don't have any steps in place to prevent hot-linking, but seriously frown on it. Therefore, you need to use common sense when posting an in-line image from another site using the methods described above, since hot-linking does use the hosting sites bandwidth to serve the image.
2) Please take steps to ensure that pictures posted in-line as described above are no wider than 800 pixels. To find out what the dimensions of the image are, just follow the steps described in Step 3 above to get to the Properties box. The images physical dimensions will be listed there. As long as it's no wider than 800 pixels, it won't stretch or break up a forum's layout, which will force users to scroll sideways to view your post...AND every other post on that page of the thread.
Good luck! :thup:
travlinjohn
Re: How to post pictures on the forums
Post by travlinjohn »
I followed the directions to a "T" and now have two of the same photo in my album. How do I delete one of the pictures?
"Laugh Hard, Hang Tough, Lend a Hand"
I will try to fix it for you.
jzjames
Post by jzjames »
I’ve enjoyed this forum since 2005, it’s much better than < the other one > !!
The posting of pictures is a drawback though.
I’ve tried many times to easily post pictures, pixels, resizing, URLs etc. but I’m just not too bright when it comes to that. I always got bogged down.
Wish we could just select an image from our albums and hit “add” to post our pictures. But we cant have everything, right?
Actually, you should be able to:
When you post - click the tab that says "attachments" click "add file" and then i believe there will be a button for "display in line".
I do think there is a file size restriction. Some folks have easily reduced them by taking a screenshot on their phone.
DisneysPatB
Post by DisneysPatB »
Tricky part is you can't just add the image from the first link when you lick on your images from the gallery. You must click on the image again so that you have a source image filling your screen and then add that URL. Until I figured this out, I never could post any images properly.
This the the hyperlink/url without the tag http://www.fordification.com/forum/app. ... 898/source
Adding the tag inserts the image correctly.
[ img ] [ / img ]
Hyperlink goes in between these two. Just make sure you don't add the spaces inside the brackets. They are there in my post for instructional purpose only.
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
jzjames
Post by jzjames »
DuckRyder wrote: I do think there is a file size restriction. Some folks have easily reduced them by taking a screenshot on their phone.
So if I’m working from an apple ipad could I take a screenshot of my picture in my gallery, and use THAT image to post?
Would that accomplish the resizing for the max. 800 pixels width?
DisneysPatB
I haven't tried them, but there are a couple online free resizers.
https://imageresizer.com/
http://www.simpleimageresizer.com/
https://resizeimage.net/
I am sure there are free resizers on the Apple app store, Microsoft has several.
I believe so depending on you iPads settings.
IOS also has an editor built in, but i will have to play with it to see if it will reduce...
jzjames
Post by jzjames »
“First of all, to get a picture show up inline in a message, the pictures HAS to already be online somewhere, not on your computer.”
“The important part is getting the pictures off your computer's hard drive and onto a server somewhere on the internet where they can be accessed.”
So this is the key, right?
I did have a image hosting site (2 actually - photobucket and picturetrail)
Lost both sites and all the pics I had on them.
basketcase0302
Post by basketcase0302 »
="jzjames"]“First of all, to get a picture show up inline in a message, the pictures HAS to already be online somewhere, not on your computer.”
YES.
It's why all my pics are gone, (when photobomb started it's greedy "pay for play" scheme years back I said screw them and left).
Another key like said above is the size, (I can't remember what size Fordification allows) but remember automatically resizing EVERY TIME I''D UPLOAD TO MY "PHOTO HOST SITE". That way you won't get an error message once you attempt the link to Fordification. :wink:
I started using IMUGR app on my phone, (was another free one) but haven't spent a lot of time with it. There are several free ones now.
