Hey all,
Looking at a Borg warner t5 out of a 1982 chevy s10. Would this work as a swap for my NP 435?
Thanks.
T5 transmission swap
1970 F100/302 5.0/4 speed/ Ford9inch 3.70
- basketcase0302
Re: T5 transmission swap
Two things for sure I know is that you'd have to run a transmission adapter plate and flywheel, and you'd have to adapt/marry the "wet clutch" to the truck.="Blueford1"Hey all,
Thanks.
Look for the same T-5 in a Fox body Stang' would make it much easier.
![2 cents :2cents:](./images/smilies/icon_2cents.gif)
You can use an adapter that goes between the bell house and transmission much simpler and cost effective. I posted a little more info on your other post in the engine section
