hfdco4
Post by hfdco4 »
My new welder is amazing compared to the HF MIG110 ac unit I have been using.
This easy mig is a DC machine and welds so much better. Only a 125amp machine but great for me.
Paul
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
Fordkid68
Post by Fordkid68 »
Looks great!
Adam
My first truck,
1968 F100 lwb 2wd soon to have a 351w, 5-speed
http://www.fordification.com/forum/view ... 15#p771357
^^Build Thread^^
99 F250 super duty, 7.3 diesel!
04 Subaru Outback (daily driver), with a 2.5l boxer H4
(no other projects, YET!)
"Might be crazy but I ain't dumb"!
hfdco4
Post by hfdco4 »
Thanks, feels great to get another task checked off the list.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Looks like I will get more done on Friday as the humidity will break again. Going to start cleaning out the bed so I can get going on another project.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Finished the parking pad for the truck build. Another item truck related checked off the list. Took 3 loads in the 2016 F150 for a total of 4200lbs of materials moved in about 2hrs.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Got the bed cleaned out. I have to take a good look and see what areas need to be fixed. I know I need some patches in the floor and there are dents in the wheel wells. The good thing is I have the spare bed to use for patches as the sides are pretty bad.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Power washed the inside of the bed, also did the Hood and Passenger Door while the pressure washer was out. I now know the areas of the Bed that need to be addressed. I also found a spot on the inside of the hood structure I need to repair. Now I have some work to do inside the garage.
Paul
:fr: FE390PC
1970 F250 4x4
Fordkid68
Post by Fordkid68 »
Awesome! Glad to hear your making progress.
Adam
My first truck,
^^Build Thread^^
hfdco4
Post by hfdco4 »
Slow, but prgress.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
So zero progress due to overwhelming heat! I am making a go forward plan now. Looking at getting the Engine, Trans and T-Case installed then drop the cab back onto the frame. I will set the bed on stands in the garage annex to work on that while the truck is in the garage.
Paul
:fr: FE390PC
1970 F250 4x4
cumminskiller
Post by cumminskiller »
hfdco4 wrote:So zero progress due to overwhelming heat! I am making a go forward plan now. Looking at getting the Engine, Trans and T-Case installed then drop the cab back onto the frame. I will set the bed on stands in the garage annex to work on that while the truck is in the garage.
Man I hear ya! It's been so hot. Gonna have to hit it hard when it cools down. Best of luck to you!
1967 Ford F100 Ranger 2WD Shortbed = Playtoy
2002 Ford F250 Powerstroke 6 speed = Towpig
2017 Ford Fiesta ST = Daily
hfdco4
Post by hfdco4 »
Thanks Man, I am hoping to get something done!
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
So no progress still. House chores and life are taking priority. And now a little bump in my schedule due to a possible work conflict. Should have a better idea of how much conflict Monday or Tuesday. Hope everyone had a great weekend.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
So it looks like my work trip is off due to a 10 day mandatory quarantine requirement. So back to cleaning. Made one trip to the scrap yard, and have a second batch almost ready. I am amazed how much scrap prices have gone up! Well back at it tomorrow.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Did the second scrap run. The first one was about 138lbs on aluminum and some small items. Second trip was 24lbs of copper and 8lbs of brass and a couple small items. Total for both trips...... $150. I feel pretty good about cleaning now. Today I was able to get rid of some straight up trash!
Paul
:fr: FE390PC
1970 F250 4x4
