Is it hard to change the C4 auto trans. seal?
- jzjames
-where its leaking and dripping? Probably the front seal?
- The Bandit
Re: Is it hard to change the C4 auto trans. seal?
The C4 has been known to leak from the front seal however the o-ring and the seal for the linkage is another place that the C4 is well known for leaking and those are time consuming and require a little knowledge to replace them.
"Don't believe everything you see and read on the internet." Abe Lincoln
1972 F100 custom SWB 302/C4 Auto PS No AC Wimbledon white and rusty..
It is quite easy to change the front seal on any automatic transmission ONCE THE TRANSMISSION IS REMOVED FROM THE VEHICLE.
