Hi all. I removed the heads off my Ford 302 W. This is the first time I attempted to do this type of work. My question is, do I need to remove the rockers to reinstall the heads? Can I torque down the head bolts with the rockers and pushrods in place?
Thanks!
302 Heads Install
- jgf100
302 Heads Install
'70 F100, 302 C4
Re: 302 Heads Install
All I've ever done was loosen the rockers enough to swing them to the side and pull the push rods out. No need to remove the rockers but I wouldn't want to torque the heads down, upon initial install, with the push rods in and the rockers torqued down. Any minor variations even in head gasket thickness could make a substantial difference in rocker clearance. If you had the heads decked even more so.
- jgf100
Sounds good. Makes sense. Do you happen to know the correct process for bolting down rocker pedestals after installing head? Im guessing I need to bring cylinder to TDC on the compression stroke and bolt down the rockers on pushrod?sargentrs wrote:All I've ever done was loosen the rockers enough to swing them to the side and pull the push rods out. No need to remove the rockers but I wouldn't want to torque the heads down, upon initial install, with the push rods in and the rockers torqued down. Any minor variations even in head gasket thickness could make a substantial difference in rocker clearance. If you had the heads decked even more so.
'70 F100, 302 C4
This is a pretty good write up.
https://fordification.com/forum/viewtopic.php?t=47128
- jgf100
Awesome! Thats exactly what I needed. I will install heads hopefully this weekend. Thanks Again.sargentrs wrote:This is a pretty good write up.
'70 F100, 302 C4
- basketcase0302
That's a good write up on the 302 rocker "adjustment" Randy.
It's one of the main reasons I love the 302 rnghine family, (the ease of the positive stop valvetrain assembly).
I know, right! I was searching the web for good info or videos or something that would be related to our trucks then thought "Wait, let me search the forum!" Should have come here first. You want info on bump side trucks you go to Fordification.com!
