F600 OR F700 CAB SWAP WITH A PICKUP
HELLO I WAS WONDERING IF ANYONE COULD TELL ME IF A LARGER TRUCK CAB F 600 F500 F750 CAN BE CHANGED OVER TO A F 250 4X4 PICUP.. 67-72 ALSO WHAT THE DIFFERENCES ARE.. CAB MOUNTS ETC. IF THE LARGER TRUCK CAB MOUNTS WILL NOT FIT HOW MUCH TROUBLE WOULD IT BE TO REPLACE BACK AT THE FIRE WALL.. THANKS DWAYNE
- spartman
re: F600 OR F700 CAB SWAP WITH A PICKUP
This picture shows the light-duty trucks' dash that is notched for the steering column, whereas the medium-duty trucks' dash isn't notched...the column goes completely under it and down at a different angle, plus the F600 dash doesn't have the necessary provisions for mounting the F100-style steering column:
In addition to the steering column problem, the hood hinges attach to the firewall instead of the inner fenders:
- flyboy2610
What Spartman meant by shouting is please turn off yours caps lock key.
It makes your posts harder to read.
Welcome to the forums! We are glad to have you with us!
- mk
The front cab mounts are also totally different meaning a lot of time will be spent cutting, trimming and welding on the firewall
mike
mike
- marz68
- 67RED
i think he has a problem with CAPS
steve
Life is 90% how you take it10% what you make it
