Has anyone experienced a whistling noise when pressing the gas pedal into the higher rpms. Sounds like the build up pressure from intake for the transmission to shift to higher gear if that makes sense. Just curious if theres way to quiet it. Researching first bc God knows I've learned my lesson for messing with parts that are working haha
Whistling noise
Whistling noise
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
Re: Whistling noise
Sounds like a vacuum leak somewhere. Does it do it any time it revs (even in park or neutral), or just while driving?
1970 F100 Ranger XLT 390 3 speed
- 1972hiboy
Re: Whistling noise
The autolite 2100 has a natural tendency to make a whistling noise under acceleration. But if this is something out of the oridinary for your truck then I would agree with vacuum leak being the first thing to check out.
Rich
Dont eat yellow snow.....
- jzjames
Re: Whistling noise
Do you have the emissions air pump on it? That was the culprit on my inline-6.
Re: Whistling noise
That's what I thought, I havent checked yet. Only when it revs/drives390xlt wrote:Sounds like a vacuum leak somewhere. Does it do it any time it revs (even in park or neutral), or just while driving?
Re: Whistling noise
It has a Holly 41601972hiboy wrote:The autolite 2100 has a natural tendency to make a whistling noise under acceleration. But if this is something out of the oridinary for your truck then I would agree with vacuum leak being the first thing to check out.
Re: Whistling noise
I dontjzjames wrote:Do you have the emissions air pump on it? That was the culprit on my inline-6.
