Will it bolt right in? Any mods needed to the driveshaft? Ijust picked the truck up from the shop and the tranny (C4) is going. It slips pretty bad going into 3rd. I found a C6 on ebay for $150 used.
http://cgi.ebay.com/ebaymotors/70-85-Fo ... 8001045093
C4 to C6 swap?
- 1968flareside
C4 to C6 swap?
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
re: C4 to C6 swap?
I know the C6 is longer so the driveshaft will need to be shortened. I think the perch for the transmission mount is located further back too but I would think you should be able to slide the crossmember back--probably would even have the holes drilled for you. I would think the linkage would take some messing around with too--but it should be doable.
I'm sure more will chime in here. I've done the swap but in my Mustang when I went FE--it was easy and in these trucks it should be even easier--
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
- 1968flareside
Thanks, anymore?
1999 F-150 XLT 4X4
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
- pat67shorty
- 1968flareside
Already done. Still acting up.
1999 F-150 XLT 4X4
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
