Water pump rebuild or new
ebaby35
Post by ebaby35 »
Do people rebuild there pumps or just buy new? I'm trying to save money and d9bt mind learning something new, was just wondering if people did it.
Mach428
Re: Water pump rebuild or new
Post by Mach428 »
If you're trying to keep your truck as original as possible and if your WP has the correct casting numbers, I would have it rebuilt. That said, if your WP is not numbers matching or you plan to install a higher performance engine, I would go with a HP pump such as Flow-cooler. They are not cheap but have a much higher flow capability
