Hello all,
So After two weeks of searching the internet, I’ve come up empty. The distributor number is long gone, other than the cast 12127. So that dosent help. Ive dug through the master parts catalogue and I’ve got it pretty well narrowed down.
So it’s a dual advance distributor, for a 240-300 six, single port on the advance canister.
This is what I’ve got:
D2UF-12127-DA
-->replaced by D2UZ-12127-D
Motorcraft # DA-1144
Replaced by D3UZ-12127-B (which is what I think I’ve got in the pickup)
———> diaphragm 318 ———> D2UZ-12370-A (motorcraft DD-347)
So any help would be appreciated, standard motor products has a great online catalog but I can’t seem to find the dang thing.
This is also the distributor I bought when I switched them out to get away from the load o matíc.
https://www.oreillyauto.com/detail/b/re ... -100?pos=1
Thanks,
Wyatt
Vacuum advance part # needed
- colnago
Re: Vacuum advance part # needed
Try looking at Napa part numbers vc970 and vc975. Both are single vacuum port. Hope that helps.
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
Is this what you need?
https://www.summitracing.com/parts/smp- ... refilter=1
You may be able to glean some info from this listing.
https://www.ebay.com/itm/OEM-Ford-Motor ... 2680017073
