1972 Ford F100 Project.
Re: 1972 Ford F100 Project.
The seat got removed, sure was a lot of dirt under it.
- Manny
You said -30-40 degrees celsius??? Jeez that is cold cold. I am amazed. Your progress is good sorry you have to go holding pattern but understand.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Yes, it does get that cold here, not for awhile yet,,,starting in January. But, I have some other fall work to do before the snow flies. My snow plow truck is a 1990 Ford F150 4x4 that I bought new. The upper intake manifold is leaking anti-freeze and I am just putting it back together. That took a few days, the distributor was frozen solid. It took me a day to finally get it to move and pull it out. Hopefully I have the leak fixed.Manny wrote:You said -30-40 degrees celsius??? Jeez that is cold cold. I am amazed. Your progress is good sorry you have to go holding pattern but understand.
- hfdco4
Glad you got the plow truck done.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- Manny
Gotta have your work horse ready to go no doubt. Hopefully all is right with the plow truck!!
All seems to working with the plow truck. The anti-freeze leak seems to be fixed.Manny wrote:Gotta have your work horse ready to go no doubt. Hopefully all is right with the plow truck!!
Not much going on with the truck now. I did find another F100 from another neighbor down the road. It looks like a 1970 Ranger. The motor is pulled, but the inner fenders look in good shape. The side molding on the fenders, cab and box look in decent shape also. I have permission to pull the parts. Cannot believe there are so many bumps hiding in the bush in my area.
- Bullitt74
Looks like she’s been there a while! Good find!
The 1970 Ranger went to the 3.5” side trim that covers the entire bump. Wonder if it’s a 69?
Steve F.
Red Deer, Alberta, Canada
- Manny
That is a good find. It must have been sitting a while or the salt would have got it i think. Or are they just as bad sitting up there?? Gotta love more parts!!
From what I am told is was bought as a parts truck in the mid 80's. It has been sitting there since. They don't rust out as bad sitting, but still rust. The worst is the tree leaves collecting and holding water.Manny wrote:That is a good find. It must have been sitting a while or the salt would have got it i think. Or are they just as bad sitting up there?? Gotta love more parts!!
- Manny
Yep i understand it same thing as down here the water and leaves. But the salt not spinning up in the wheel wells has to help.North56 wrote:From what I am told is was bought as a parts truck in the mid 80's. It has been sitting there since. They don't rust out as bad sitting, but still rust. The worst is the tree leaves collecting and holding water.Manny wrote:That is a good find. It must have been sitting a while or the salt would have got it i think. Or are they just as bad sitting up there?? Gotta love more parts!!
