heater hose valve
Ron_Hall
heater hose valve
Post by Ron_Hall »
Good afternoon guys... I just have a quick question about the heater hose valve and which hose it goes in or if it even matters.
Thanks
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
colnago
Re: heater hose valve
Post by colnago »
On my truck, I have that line running to the fixture on the intake valve. Operationally, I wouldn't think it would make much difference.
Ron_Hall
Post by Ron_Hall »
colnago wrote:On my truck, I have that line running to the fixture on the intake valve. Operationally, I wouldn't think it would make much difference.
Thanks Joseph. I was think the same.
Ron
One owner...
Lee
Post by Lee »
Hi,
Theoretically.... I don't think it matters.... Mine is on the hot supply line to the heater core.
Lee
Ron_Hall
Post by Ron_Hall »
Lee wrote:Hi,
Lee
You can't see from my pic but the valve is in the hose coming from the water pump as is your's. I too think it does not matter.
Thanks Lee
Ron
One owner...
DisneysPatB
Post by DisneysPatB »
https://fordification.com/tech/images/s ... heater.jpg In the picture, the valve is on the hose closest to the fender, hose routed to carb.
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
colnago
Post by colnago »
DisneysPatB wrote:... hose routed to carb.
The carb? Doesn't compute. One line runs to a fixture on the intake manifold, the other runs to the water pump. Am I missing something?
Lee
Post by Lee »
Hi Joe,
In reference to your question of routing the hose to the Carb,.... No... Your not missing anything...I have seen some trucks where the heater hose routing had 1 of the hoses go over to the Carb and was used to heat up the choke mechanism..... Instead of using 12volts to heat it up.
Lee
Ranchero50
Post by Ranchero50 »
If your intake has "HOT" exhaust gasses going through it you should have "coolant" going through the spacer. The T from the heater hose also kept coolant flow through the block consistent when the thermostat was closed in our trucks (and honestly that's why a lot of answers in this thread are wrong). In the car they controlled the heater temps via air bypassing the core. If you want your engine to warm up quicker do like the 5.0 mustangs did and install a restriction port into the heater hose. You'll have warm air out the heater within 2-3 minutes versus 5-10 without it.
